Using a speker terminal in a sealed box
  • 3
I would use these then
I would say dont get the screw ones. I had problems with my old box and the wires coming unscrewed. Unless you want to solder them into place - I would highly recommend stopping at Radio Shack and getting the spring loaded ones. They claim to leak on the reviews - but I wired mine up and just siliconed everything on the inside (literally filled it with silicone) and bam, airtight. Probably cost me about 9 bucks with the terminal and silicone.
856
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
700
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
9
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
4
sbelew
sbelew
New Port Richey, FL
jmgb4
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
