Head unit snagging - using Connects2 interfaces.
  • 2
Geoff.C
CarAudio.com Newbie
Hello,
I am a relatively competent DIY fitter, but have run into a snag that I would appreciate some help with please.
I am upgrading the head unit in my Fiat Ducato based camper, and am currently fitting a Pioneer SPH-EVO950DAB unit.
I have sourced an interface kit (with new fascia) from Connects2.
Within the kit are a 'Male Fakra to SMB Female Antenna Adapter' and a 'Fakra to DIN Aerial Antenna Adapter'
Both of these connecters have a thin blue lead with a metal clip on the end (see photo below).
I am guessing that this is a grounding lead, but the connection on the end of the lead does not appear to be very strong, and I am not sure where to connect it.
I currently have it clipped to the head unit chassis, but the DAB signal is rather flaky. The connection does not feel very secure, and I think I have probably got it wrong.
Can anyone advise me where / how this should be connected please ?
Many thanks
Geoff
Loose grounding could cause the spotty issue. I would find a good existing screw that is mounted to the back of the internal dash wall. Remove it, sand down the area and crimp a ring terminal or spade onto that accessory and screw it down good and tight. Changing the connector to a ring or spade terminal is key, could try and ground it to the same ground as the HU preferably.
EDIT:
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, not a ground.
Thanks for that - Do we think that the connection is a grounding lead ?
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, You will connect it to the blue/white remote or the solid blue antenna turn on lead from the harness you are using.
My apologies, I hadn't finished my morning coffee! That solid blue wire is a power lead, You will connect it to the blue/white remote or the sold blue antenna turn on lead from the harness you are using.
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know.
Cheers !
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
490
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
593
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
723
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
Geoff.C
CarAudio.com Newbie
Geoff.C
Merseyside, UK
Geoff.C
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
