Tweeter problem
  • 2
RUN OUT NOW
CarAudio.com Newbie
ga
I have a 1k watt ds18 amp running 4 ds18 250w rms door speakers I have a 2017 trax.
But my problem is my tweeters are tied into my 2 front door speakers so I can not turn them up at all or I will blow the tweeters any idea how to fix? Or add some kind of blocking device?
tweeters need a crossover to block the low bass from getting to them. These are separate tweeters up on your dash?
Tweeters have a built in crossover that’s not the problem thought.. the problem is only my door speakers are getting my amps power and for some reason my tweeters are getting my front door speakers amps power even know my tweeters shouldn’t be getting any extra power but head unit power.
They have a crossover they are separate mounted on my pillars the problem isn’t the crossover the problem is they’re getting unwanted power from my AMP they must be tied into my front door speakers. My tweeters get louder as I turn my gain up along with my front door speaker so I need a solution on how to stop my tweeters from getting my amps power
You used the factory wiring? If so, the factory has them wired in parallel with the door speaker. You’d need to run your own speaker wire to the tweeters.
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
6
547
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
Tons of options in that budget, including the cost of installation,
10
999
It'll look like a "Hawaiian professional" did your install then 🤣
17
RUN OUT NOW
CarAudio.com Newbie
RUN OUT NOW
ga
SlugButter
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
