tube port length question
  • 2
Bobby322
TX
Quick question..
When using tube ports, and you are leaving some port in and some out, do you factor in the .75'' of wood the port passes through, and add it do the total length? I want 12'' in my box, and about 11'' out of my box for 23'' of port. Should I cut it to 23.75''?
Also, leaving port out of the box won't change tuning or anything will it? It just helps on saving space? Im at 4.75 cubes @ 32hz, and the calculator calls for 23'' of port for an 8'' tube. I'm porting out of the top of a 21'' tall box, so will going about 1/2 in and 1/2 out affect anything except cutting the port displacement in 1/2?
Quick question..
No. Measure from port end to port end.
No.
No.
Sure
Correct.
thank you sir for the simple post //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
758
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
939
Bobby322
Bobby322
TX
Bobby322
    May 24, 2024
