Thors 09 Build Log
I like the sidewalls and bottom of the box thing. Bet it helps with the lows like that.
I don't see a prob burpin a 52, but the 49.9 class might get a lil hairy. 30sec of full tilt with 5k per sub, thatd worry be a bit.
Good luck.
What 12s did you break a 141 with?
PG Titanium 12dElite Probably could have gotten alot higher but I never played with boxes for them.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i can't wait to hear this ish over the summer
It's gonna Wang brotha!
Good luck.
Will probably be giving ea a comfortable 3500+ That should do the trick!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
well i tested my voltage and im not getting that bad of drops.. hit the 11's once or twice but mostly stays in 12's-13's.. guess im hitting a limit with the amp. guess box change or more power.
Unfortunately there is no way to tell you for sure this is what you need. When I started this build last yr. I bought the 5k. With a pr. of 12's I could only break a 141. Most of which was due to box design.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Then I bought the 10's and was given a box to work with. 143+
Then I built another box using the current one I had to go off of. 145+
Changed impedance 147+
Put in a floor and sealed it 149+
Do ya kind of see what I'm getting at. It just takes time! There is no guarantee that any one set up is gonna give you high numbers. You have to learn your vehicle and feed off what it gives ya.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
joining team DEFJ gained....X dbs,lol.jk bro you've worked ur ass of and its really showing,cant wait to tear up the lanes with u this year.watch out TNE!!!
Joining TeamDefJ Priceless!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You've been there every step of the way!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This is gonna be a Great Year! Could be a record setting yr. Ya never know;)
where did you fit the 2400's?
how wide is your box?
As of right now I only have one 2400 in the trunk. I plan to put the second one in the wheel well when I take the box and floor out. Probably wont be in for a month or so. Still have alot of tests to do before I get there. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Don't remember box width but i wanna say 35ish:(
Ver nice reading on the TL, man!
Can I go to the shows and see the team AQ? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Hey man, have you ever thought about putting a loading wall in front of the subs? Just for shits and giggles, you've done all this testing and stuff. I bet the results would be interesting to see. Keep the loading wall in front of the subs and you might have a really efficient BP but who knows?
Absolutely:D
what class are you going to be running?
Street C DbDrag, Hoping for the 149.9 class in Bassrace and
of course Woofer Cooker 1 with 1 5k and 2 batts and Woofer Cooker Pro with 2 5k's in TeamNorthEastSPL
That is something I have thought about and tossed around. I'll cut a piece of wood and do that. Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
945
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
882
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
7
953
thorshammer1
thorshammer1
Auburn, NY
uGotF-ckedUp
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
