The Saturn: Can't stop there. (Dual 18's upgrade)
Cool cool, my buddy had some SSD's and I was very impressed with them, you should like them. ***** about not having anything to compete with though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
yea.. it does ****.. i want to get out there and put up some numbers and hopefully impress somone haha.. oh well. . . what kind of numbers did he pull with his ssd's?? like i said. im hopeing with them walled and putting 1000 wrms to each i can do 147's on music. and hopefully 150+ on burps
Awesome build, GL to you.Definitely biting the pocket screw idea.
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He actually got (I believe) a 148 @ 34Hz //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif just running the pair off of a SAZ1500...walmart battery upfront, no battery in the rear, car on, sealed up, etc...If that was accurate Im pretty impressed but it's been a while (it was with a 96 Saturn SC2, all trunk...subs up, port back)
Is this getting ported through the rear deck?
Yep //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...big ol' port in the rear window, down the road it'll actually be one solid surface rather than it just poking through the rear deck.
Yea, that was one thought but it wouldve been a good deal more complicated and the rear window wouldve probably had to have come out for the install itself...now the rear window wont need to come out for anything except maybe finishing touches to get the rear deck one smooth, solid surface I may be pulling the rear window and reinstalling it when im done with that. And thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Don't mean to thread jack but how long do you think my stock alt will last off of an HK4000D with two HC2400s?
Drew
as long as it would without,
I totally forgot that you have a stock alternator. Then I should be good to add that second HK4000D when I pick up my other sub.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Thanks
Drew
Alright, it's starting to look more complete //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Made a piece to go across the opening to level it off with the rest of the front chamber/section..
Mounted..
The wall of mirrors (random)..
Got the other side panel mounted tonight too...got the holes drilled for mounting..
Mounted..
A few over-view pics of everything..
Got a piece cut for the corner area of the side...and another but no pics of it..
Those will go in tomorrow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...more then
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
Pioneer~Saturn
Dr. Enclosure
Pioneer~Saturn
Dayton, OH
Johnny Law.Lulz
maylar
    Jun 2, 2024
    Jun 1, 2024
