System in the works
  • 3
bizzy07
IA
I have been planing this system over the last 6 months and buying things slowly. Just looking for opinions.
Alpine cda-9886
2 AQ HDC312-A d2's
2 AQ 2200d's
2 AQ comp sets
1 AQ 4x90
This is all going into an 01 Olds Alero 4 door.
Subs will be in roughly 4ft^3 @ 38hz after displacements and sealed off from the trunk.
1 set of comps will be in custom door pods powered by the 4x90.
The second set of comps will be in the rear deck powered off the factory amp, head unit, or 4x90 cant decide.
As for electrical:
220 amp HO alt
2 optima d31t's (got a good deal)
1 optima 34/78 up front
2/0 big three
2/0 to rear batts
4ga from front batt to 4x90
1/0 linking batts and providing power and ground to the 2200's
All wiring besides the 2/0 (welding wire) is knu wire
Also picking up two shop packs of damplifier pro
This is my biggest and most expensive build to date and I just want to make sure im not missing anything and if my planned electrical can stand up to the demands of the system. Once everything comes in and it warms up I'll be sure to post a build log.
is all that damplifier pro really necessary? stuff is expensive, might not be a bad idea to start out with 80sq ft bc i thnk people sometimes go overboard and spend alot more money than is necessary.
I figure I will test as I go and I'll sell what ever I don't use afterwards. I have a feeling I will use it all though because rattles annoy the hell out of me.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
470
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
909
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
941
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
bizzy07
bizzy07
IA
bizzy07
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
