Swap to Kenwood 318DDX, amp, subwoofer help needed
  • 3
TCAS007
UT
Hi guys!
I am new here, just found the board when I was trying to find help for a small problem I have.
I own a 2007 Ford Expedition Eddie Bauer and the stock CD6 MP3 radio broke. So I got the Kenwood 318DDX installed. They seemed professional and charged me adapters, harness kit,...
While I was driving I had no time to play with the settings but after being home I definately found out that there is way less BASS then before with the stock Ford radio.
I am almost sure that I have a sub with a Ford amp at the left rear side and that it is no more working.
The radio settings do not give me the subwoofer option either.
So as I have to drive for an hour to go back on Monday, please tell me if there is anything I can fix or check myself. Or is this just normal? I doubt it.
I have to admit that I never had to do with anything Ford and radios so I am a bit lost. But my ears know what a bass sounds and even the sound is good, there is not bass enough.
See the attachments for additional info.
Thanks so much!
Eric
Sounds like the factory subwoofer is no longer working.
You are going to most likely bring it back to the shop that installed it.
I would think getting it to work with the new radio should not be too hard.
Ya take it back to where you had the HU installed, and let them know that there is an issue with one of your speakers/subwoofer, and make them do it right.They should not have let you leave with the speaker not working properly, or at least letting you know that an extra part may be needed?Sounds like they tried to pull a shaft on you/lazy installers/taking your hard earned money:rage: Dont mess with anything other than the HU, as if you do, they will say you tampered with it, and void the workmanship/so called warranty.You are the customer, and should have received the service that you paid for,and you did not IMO:(
Only reason I would use the kick location was if the speaker magnets did not clear the door's regulator/glass. As for the 3way location, I would...
9
Hi I have a 2006 Porsche 911 with the original PCM head unit/system. The prior owner had a Mobridge ABT2010 unit installed - it uses a Y cable...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
392
TCAS007
TCAS007
UT
audiobaun
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
