Please help with all possible outcomes and solutions
um, why are you mad at me i’m just trying to get a solution to wire all this **** up and you’re getting mad at me because of the **** i’m trying to hook up the way i want?
those ratings are inflated....."bulked up" to get people to buy. You really think if that were true that every single one of us here would be running SSL and Boss brands??
The last post on the first page answered your question.
Follow that and you'll have all your subs hooked up.
Honestly, if you're tight on budget I would just wait until you can spend money towards better equipment.
If you want to be "loud" its expensive.
how do i not listen and all i want is to wire 4 subs with what i have?! wtf is the problem
I've already told you why. The other problem is your not listening....that's the problem. Running mixmatched subs won't be the same as running normal sized subs. You wanna do it because you think it's cool. If that were the case, we'd all be doing it.
okay without adding to it what’s the most powerful way for me to wire two twelve inch subwoofers(dual), two ten inch subwoofers(kicker), two ten inch subwoofers(mtx audio) four hundred watt dual amp and twelve hundred watt ssl amp. what would you hook up and leave out with all that, if you had to have something hooked up for somebody tomorrow
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
danemd245
danemd245
Tennessee
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
