Please help with all possible outcomes and solutions
oh okay well with just my 2 12s hooked up i’ve got that and the bass boost almost all the way up and it sounds good but i want more
Should never turn bass boost on.....reason being is because that will lead to clipping, will destroy your subs.
Also that amp doesn't say rms ratings, just max power, same as peak power. You always wanna look for rms ratings, never peak power. Peak power is only for a few seconds. rms is continuous, meaning all day and night. That amp MAY be putting out 200 watts at most. You need a much bigger amp to run those 12's. No wonder your asking for help.
lol thank you but i only want to run 4 subs, if it would sound better with the 4 10s hooked up instead of 2 12s and 2 10s then i guess i’ll do that but i like my 12s and that amp you pulled up is close except max peak is 1200 and 4 ohms all around except 2 channel is 2
I def wouldn't run 2 diff branded pairs of subs either.
Better route to go is sell all that stuff and we can help you achieve loudness with better equipment.
Ya same amp I just posted. Your not gonna get anything more out of that junk amp. You want more power, gonna have to pony up some $$ to get ya some.
Because that amp says MAX power, not continuous as I already explained/told you.
---------- Post added at 12:10 AM ---------- Previous post was at 12:10 AM ----------
****** Dual...people like you that **** us off because of cheap pricing on JUNK AMPS.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
danemd245
danemd245
Tennessee
hispls
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
