SOLD Please Help Please Help
Can Someone Tell Me Which Is Better Sub In Sound Quality Jl12w6 Or Image Dynamics Idq12 V.3 ? My Amp Can Only Push 600 Rms Thanks For Help.
sound quality tends to be an opinion type thing. You should try and make you own decision on these two, if you can.
i have a w7 in the past with 600rms watts rms amp and they not that good either because i think they're too booming , that's why i down grade to w6v2, if anyone have idq12v.3 let me know i will buy thanks.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
970
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
kevin lu
727south
kevin lu
clearwater, fl
kevin lu
    May 20, 2024
    May 20, 2024
