opinion on 22s
I like your 1st set, but not too sure about the 2nd set you posted.
I think you should keep the ones you have right now and have them repainted and then you are god to go. just my 1 cent.
the door is a FLY DOOR conversion.. u unbolt the bottom hinge and bolt in a short shock (like hatch/hood shock) to hold the door up or down.. cost like 20bux to do.. and is reversable as easy as removing two bolts, and replacing the factory bolts
Looks messed up, got any more pics of how that door thing works? I just cant grasp the concept.
no pics..
1) unbolt bottom hinge
2) swing hinge into "Open" position..
3) add a washer and bolt the factory bolt thru a short shock.. tighten the shock down to the bottom factory mounting hole
4) unbolt the bottom bolt on the top hinge.. and swing the door down
5) bolt the other side of the shock to the bottom hinge hole.. using a short bolt/nut
now you door will stay in position
thats what it called jackass, i didnt make it up.. and i dont believed i asked your goddamn opinion on my car, just wheels.. so fall throat first in a pool of dicks
didnt give you my opinion on the car stupid fuck I said cheap ass wheels and no the door is not called that try again
I don't even think you need to do that. You can use WiFi to connect wireless Android Auto but doing so kick out the units ability to self stream...
878
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
Sundown does underrate their amps. And by alotmon the salt line The salt 200.4 I would bet would walk all over the t1000-4 but the Rockford is a...
abrhino
Big White King Kong
abrhino
middle TN
abrhino
