Need Help With a mach 460 sound system Please!
  • 3
studerman1
6
Iowa
I have a 1998 mustang gt with the 460 mach system. I installed a different head unit, and it work only with the care turned in the on position. Also, the rear deck doesn't have any base (sound only comes from the tweeters) I heard it has been done, but others say it cannot be done.
ckevzkbet
4cxsk8jsj
If you need any more photo angles Just ask I will take them
Thanks for all of the help
If images don't work here are the links:
http://postimg.org/image/ckevzkbet/
http://postimg.org/image/4cxsk8jsj/
Are they stock amps or no ?
Both Amps are brand new in the back. So I feel like that isn't the reason
Sounds like the stock amps not working
Yes they are
Let me correct my post..
I had a taurus with the mach 460 and it did not have an amp.
The amp looking thing in the trunk is the actual headunit and the front is just the display pretty much.
And if it did have an amp then this is why you think you have 2 amps.
The only way to get bass and correct the issue is to directly wire the speakers to your new headunit or add an amp and use crossovers.
The mach 460 will need a clean sweep to get any bass if thats what you want, but it still will be weak.
Sent from my Z970 using Tapatalk
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
709
11
982
944
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
studerman1
studerman1
Iowa
los33
