RoadThunder 604 Blinking LEDs
  • 2
N3XTN3RD
Hi guys
I installed my RT 604 amplifier and Sony Xplod subwoofer in my car a couple weeks back,
it seemed to be functioning like it should. But suddenly when i drove to the bank, when i started my car again, my radio wouldn't turn on. First i thought it broke for some reason, but that did not seem to be the case, when I was back home, i was checking if all connections were still ok, they seemed to be fine. I started my car again and it was working again, this is when the problem with my amplifier started, it used to work the first 5 min and after that it sometimes suddenly worked and than turn off again. (By turning off i mean that the amps leds began flickering) Now that i have this problem for longer than a week it seemed to gotten even worse, the amp is 99% blinking and sometimes randomly it just works for a second, i also tried my previous radio, it was the same story.
I have checked ground and remote multiple times and the fuses seem to be fine.
Anybody have any idea whats wrong?
Is my amp just dying?
(Manual for my amp: http://2004.mtxaudio.eu/IMG/pdf/Manual-RT604.pdf )
Any help will be greatly appreciated.
Thanks
Thoroughly check remote wire making sure no exposed wire and at the back of the deck check all that ; connections are tight and, at the amp, too. Sounds like theirs a bad connection getting worse. Check your grounds and power.
Sent from my LG-H631 using Tapatalk
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
890
N3XTN3RD
N3XTN3RD
Belgium
OKAY
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
