Mysterious subs?
Peak power handling: 2000 Watts per voice coil
Continuous power handling: 1000 Watts per voice coil
Impedance: QuadCoilf- 1 ohm (4 X 1 ohm)
4" black anodized Aluminum voice coil former with Kapton layered protection
450 -oz magnet structure
FEA (Finite Element Analysis)
Computer-optimized aluminum basket
Extra large 10" Poly/Cotton/Nomex spider for maximum excursion
SRSf Patent Pending Voice Coil centering device
1.25" thick top plate for optimized flux flow and motor strength
High-density 2.25" wide big foam surround
Ultra Rigid/Ultra Thick "pulped" paper cone
Rubber-Toughen isolated high current Tinsel lead wire
Patent pending CWACf technology prevents Tinsel lead wire rattle and destruction
Silver-plated spring loaded binding posts
Custom engraved bottom plate
Designed and built in U.S.A.
I almost 95% sure the Concept CSP is the exact same motor as the RE Destroyer, but with a bigger spider to accomodate the 4 inch vc better than the RE did.
i was just thinking about my destroyed destroyer when i was lookin at that pic.
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
707
16
bumpin buick
Science is everything
bumpin buick
Appleton, Wisconsin
tymoto21
Decebal
    Jun 10, 2024
