Mounting amp's on sub box
MellowHype
So ive just finished building my first enclosure, and its a really tight fit in my trunk. Is it safe to mount two amplifiers on the sub box? like on the top or on the sides? Will the bass rattle the insides of the amps or will it be fine?
I was thinking of making small square mounts and gluing them onto the box and then screwing the amps onto them so im not drilling into the box.
Also is it safe to mount amps vertically? does the heat still escape from the amp properly?
Thanks in advanced.
I've mounted an amp to a box doing 153db's and had no problems. It was a DD as well, and those are very sensitive to vibrations.
Fair enough ive just got one type R 12 so i guess im good lol
Cheers bro
just like everyone else said you will be fine. you will want to change your amps far before they will rattle apart, like everyone else in this hobby
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
529
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
MellowHype
MellowHype
Uk, London
Max_Power
    May 31, 2024
    May 24, 2024
