looking for amp ideas .
  • 3
I picked up a pair of dq HDC3 12 inch subs , dual 2 ohm version and i plan on upgrading my current amp . right now i have 2 DD 1512's on a sundown 1500 at 1 ohm in a way small box and tuned to low.
I do have some ele upgrades already - xs power 3400 under the hood and 1more in back , 200 amp alt. skyhigh 1/0 wire and big 3 wires done with 1/0 skyhigh also . I maybe could get a different agm for under the hood and put the other xs power 3400 in back
I know the 1500 amp is not enough so i can do either another 1500 and strap them or sell the 1500 and do a bigger amp ( i rather run 1 amp ). With the subs ill have to run either .5 ohm or 2 ohm . iam guessing with rise i'd be ok running single amp at .5 ohms ( not sure which do good at .5 daily ) . I can do up to 5.0 TO 5.5 cf box after port ( If tuning is 35hz TO 38 hz )
With my electrical and these subs what amps will be good for me ? If i sell the 1500 id have about 600.00 to 650.00 MAX to spend on the amp.
If your planning on 3k then you might need more cash for $650. You might find one used
I fiqured id have to do used . Just not sure what my electrical will handle and if any of these are good at .5 daily .i have not had the sundown 1500 on them yet , just read its pretty small for 2 hdc3 12 .subs
older vlf 150
ampere audio 3800
soundqubed 3500
I fiqured id have to do used . Just not sure what my electrical will handle and if any of these are good at .5 daily .i have not had the sundown 1500 on them yet , just read its pretty small for 2 hdc3 12 .subs older vlf 150
ampere audio 3800
soundqubed 3500
All of those are .5 stable. With the aa3800 being the better of all 3 Your electrical isn't enough for any of those amps at .5 tho. You'll need at least a 275 amp alt. And a 6phase hairpin at that
You will need 100-150$ more for a 3k or better.
Id suggest saving the money and not rushing so you can really have a good setup
Sent from my draconis using Tapatalk
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
Hi guys, I’m John. Been out of car audio for probably 15 years or so. I built a couple boxes back in the day and was definitely a bass head but...
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Excellent choice on the SSA Evil's. :)
28
Timewarp
Timewarp
Brevard,Fl
los33
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
