Amp is putting out low voltage
  • 3
mrpep
chicago
what would make an amp put out low voltage? I have a peavy cs800x amp it runs on standard 120 and when bridged at 4 ohms I should be able to get 1200 watts rms. I bridged it at 4 ohms and only get 23 volts max which is about 125/150 watts approximately. What would make an amp do this? I realize that this is car audio but people who know the guts of an amp might be able to shed some light on this. Any bit helps ...
I got it to get a little higher - putting out low 40s - still not the 1000 rms it should put out - but I'll take ever volt I can get. I'm going to use a test time next
Does the DDT light ever come on?
Is the Power light on Channel B off?
When you say max was in the 20v out, what is max? max volume?
If that's true, how did you get it to increase into the 40s?
What is a "test time"?
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
161
6
393
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
700
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
506
mrpep
mrpep
chicago
shizzzon
