Is my sub and amp compatible with the wiring that's already set up?
If you do not have a remote wire running from the head unit to the amp you can get a turn on signal from several other places. I see in the picture the wire is running to nothing. Jumping the power wire is about the worst solution. If it absolutely had to be done it MUST be fused with a very low amp fuse. 0.5 amp is best. If you have wire running capabilities we can tell you other ways to get a remote signal.
Sorry for the late replay. We got hit with 7 feet of snow where I live feet. Based on the info you provided you can only wire it with a 4ohm load. So you would do sub + to amp Left + and sub - to amp Right -. Just because the sub looks the same in the picture it does not mean that it the single voice coil version. The only way to know for sure is unscrew the sub and take it out of the box.
Here is wiring diagram link http://www.the12volt.com/caraudio/woofer_configurations.asp
245
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
778
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
846
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
882
AmyR
AmyR
New Zealand
What was that?
Decebal
    Jun 10, 2024
