Dayton Ultimax 18"
  • 1
Hello everybody!
I'm new here obviously. I read the sticky, I know this is the noob forum. I am interested in purchasing a Dayton ultimax 18. Hence the thread name. Parts express lists this sub as have a f3( I don't think this is the right value) of between 28-32hz well P.E lists 28hz, Dayton lists the sealed as 32hz.
I'm interested in the sub because it can hit the lows in a sealed application. I figure the 18 will get plenty loud because of the cone area. I won't have to push tons of power to I think I can feed it between 1-2k of clean power and be ok. Its rated at 900rms. I've heard Dayton's are very well built musical sub's and that's exactly what I'm looking for. My plan is is build a 3cuft sealed box. Have the 18 down fire behind the drivers seat in my f150 it won't be a square box it'll have around around 1cuft under the seat behind the pass seat with 2ish cuft box so I guess it'll look like a 2cuft box with a 1cuft box attach to it. This is all pretty rough guessimation.
I'm looking for any advice on the box. Should I go an entirely different route? I know most everyone here is a lot more knowledgable than me. So I'm just trying to see if what I'm wanting to do is a good idea or not. I know ported will be louder but the recommended and optimal box sizes for Ported on this sub are not gonna work in my truck. I have an extended cab 03 f150. I'm giving up the seat behind the driver to fit most of the box and sub I was planning on mounting my amps on the side of the box so I can keep and eye on them easily. And getting the extra cuft with a box under the side of the backseat.
I know I rambled alot, sorry!
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
7
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
4
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
4
SuperScrilla
Mobile, AL
SuperScrilla
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
