I'm buyin 2day, help...
4 400w rms 12s, nothing special, 2 3013ps, 2 xw12
I think you may be under-shooting this a bit... Going with lower end amp you really want to go with a higher rms rating than you actually need, I'd go with something rated for like 2k if needing 1600...
The AP1800 needs an inline fuse of 120A, which I don't understand because my PPI BK1800 needs 160A. Both are rated 1800wrms at 1ohm.
Could audiopipe be inflating their amp ratings a bit?
470
532
563
basswiigee
basswiigee
MICHIGAN
basswiigee
