I'm buyin 2day, help...
Kenwood KFC-W3013PS:
Size 12 -inch
Impedance 4 ohms
Cone Material Polypropylene
Surround Material Rubber
Ideal Sealed Box Volume (cubic feet) 1.25
Ideal Ported Box Volume (cubic feet) 2
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil No
Sensitivity 85 dB at 1 watt
Frequency Response 34 - 300 Hz
RMS Power Range (Watts) 50-400
Peak Power Handling (Watts) 1200
Top Mount Depth (inches) 6 1/16
Bottom Mount Depth (inches) 6 3/4
Cutout Diameter or Length (inches) 11
Vas (liters) 83.7
Fs (Hz) 25
Qts 0.82
Xmax (millimeters) 15.1
Kenwood Excelon KFC-XW12:
Size 12 -inch
Impedance 4 ohms
Free-Air No
Dual Voice Coil No
Bottom Mount Depth (inches) 6 3/16
Vas (liters) 78.7
Fs (Hz) 25
Qts 0.9
the only bamf that are good is the bamf 5500 and this one bamf 4000 if you look at the fusing it will do rated
everything i read is crazy pic has four fuses all reviews say it has 3x40amp, p.a. rates at 16v, so if its 2200 rms, what do you think it will do at 14v?
why the FFFF is power acoustik even an option. No company that lies about power ratings should ever be considered.
i dont know much about audio any more just looking @ what people are suggesting in my horrible budget of 170... lol
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
474
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
533
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
564
basswiigee
basswiigee
MICHIGAN
basswiigee
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
