How to fuse amp?
Been reading up alot here and I thought the fuse at the battery was to protect the wire. Using 4 gauge and going from the front to trunk recommended fuse size is 100amp.... Hmmmmm...
If all you are running is one amp then the fuse at the battery can be used to protect your amp. simply take your peak wattage and multiply by 1.1 (ten percent) and divide by your operating voltage typically 14.4
Yes, but there's nothing wrong with fusing the wire at less than it's capacity to protect the load.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
482
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
639
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
seatown1two
seatown1two
Edmonds, WA
seatown1two
    May 31, 2024
    May 24, 2024
