Question about setting gain with an DMM
  • 4
MiniflexAlex
Leon, MX
Hello,
I just tried to set the gain on my amp with the help of an DMM.
Well, I took the cables to the woofer off the amp.
All tone settings on the HU and on the amp set to zero, Radio cranked to about 85% and the DMM leads at the woofer terminal on the amp....well, I should see a Volt reading on my DMM now but I don't....0.00V....I thought my DMM is shot so I held it on the power terminals of the amp and it gave me a reading of 12.9V...so the DMM is fine....strapped the woofers back on the amp and they are blasting, so the amp works fine....//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
wth....?
BTW. It is a American Bass VFL 175.1 pushing two DC lvl4 @ 1 Ohm...so I should see about 57 Volt right....???
Thanks in advance
Alex
Then u measured incorrectly.Did you put DMM negative to chassis ground?
I don't know what I'm doing wrong...
I did did put the DMM negative to the negative terminal on the amp and not to the chassi.
it's set to dc not ac?
Yes, it is set to DC.
One more thing. I'm not using a test tone just plain old music....but anyways, it should give me a reading and not 0.00V
I don't know what I'm doing wrong...I did did put the DMM negative to the negative terminal on the amp and not to the chassi.
Well set it to ac then, everything else sounds correct.
//content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif I'm a dumb a** //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif now it works...
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
296
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
658
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
927
MiniflexAlex
MiniflexAlex
Leon, MX
MiniflexAlex
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
