How am I going to power all of this?
Patula71
Hey guys, new to the forum and semi new to the car audio scene so I need a little assistance. I recently purchased a 15 inch power acoustik mofo 4 ohm and a 3500 watt power acoustik amp. I'm running a pretty good size battery in my truck, but I need to know what else is required to run such a powerful amp. It might be a dumb question, but I could really use some help/ recommendations. Thanks guys.
yeah you don't need anything else to run it with only one 4ohm DVC sub.
Parallel the subs coils to create a 2ohm load on the amp. Make sure your tune the amp with a DMM for like 500watts rms because that's all your getting with that amp at 2 ohms.
Come on guys everyone starts somewere.. look into a capasiror (sorry for my spelling) or just doing the big 3. Possobly a small battery in the back if you didnt want any voltage drop
for his situation, a capacitor is pointless, and so is big 3. He can run his setup as is so long as he doesn't try to pull more than 500-700wrms at 2ohms. His vehicles electrical system, I'm guessing, could handle this type of power output. Most vehicles can.........
I'd expect at most around 1000 watts out of that amp.
yeah at 1 ohm. He's wiring a dual 4ohm coil woofer down to 2 ohms.
Like I said, 500watts is your safest bet from that amp at 2 ohms.
Glad to hear it was a simple fix and the amp is working again. The 9v reading indicated it was likely a bad connection somewhere.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
Patula71
Patula71
Hazard, KY
jrdnhsnbrg
    Jun 15, 2024
    Jun 15, 2024
