proper electrical for saz3000?
302yota
im currently running the stock (5 year old) factory batt up front, 130a alt, and a kinetic hc2000 ( I bought it used, and im sure its pretty old also) in the back...all 1/0 wire, including the big 3...amp Is probably turned halfway up at 1.4 ohms on a fi sp4 18...my voltage drops as low as 11.5 volts at idle...what would be a good battery setup to be able to get the most power out of my amp? I was thinking a hc2000 under the hood and buying a new hc2000 for the rear and doing away with both batts that I have now
Your alt and batts are not enough to keep up. If you want to keep that alt i would look for a pair of Group 31 Agm's and probably a better battery to go under the hood, preferably a smaller Agm battery. That would help some. Kinetic batterys are really not as good as they are advertised to be.
I don't know why people insist on playing things full bore at idle anyway. It's obnoxious and much harder on the electrical system to boot.
well I usually like to keep it around 2k rpms when demoing, but I still have bad voltage drop then...by a "group 31" battery do yall mean like a 3100...and whats the difference between agm and non agm batts?
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
502
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos...
302yota
302yota
rockingham, NC
302yota
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
