how to install an amp to car speakers
  • 3
robert420
geneva ne
i'm helping my dad with an install on a 95 plymouth voyager rallye. i put in a pioneer headunit and it sounded good with the factory speakers. yesterday he went and bought new pioneer speakers to replace the factory ones, but they don't sound as loud... as if the head unit isn't giving them enough power. how can i go about wiring in an amplifier to the speakers???
The same way you would install an amp for a subwoofer, except that you will either run the speaker wires to the dash and connect with the factory wiring there or you can run new wire all the way to each speaker.
thats what i thought. then do you just leave the speaker wiring coming from the H.U disconnected?
Yes. Assuming you are going to use the RCA outputs from the head unit to connect to your new amp, then you simply leave the HU speaker outputs un-connected (tape them off).
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
3K
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
984
robert420
robert420
geneva ne
Jepalan
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
