Help with the 12w7
jdub486
Maryland
I just got a 12w7 and put it in a slot ported box tuned to 32hz. Gross volume is 2.25, net is 1.75. It is fully braced with a double thick front baffle. I am powering it with a Phoenix Gold Xenon 600.1 with a birth sheet that says 816 watts. It does not get as loud as I thought, nor does it sounds as tight as I thought. Is the amp holding it back? If it helps, the car is an e46 BMW 3 series with no trunk pass thru and a very sealed trunk. Let me know if you think more power is key. Factory 120 amp alternator and battery, 0 gauge power wire to d block, 4 gauge to amps.
i sent a 10w7 1200rms just fine so i think that 12w7 could use at least 1000rms to get what your looking for. and like was said, luxery cars are harder to get loud.
-vic
ya fargof has a good point. try different ways of aiming it in the trunk, too. a bigger amp might help, but not as much as you would think. also, if you can, try different enclosures, bigger, sealed, bandpass, etc. and see what you like best
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
215
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
634
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
404
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
379
jdub486
jdub486
Maryland
Dak446
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
