help with amp and batterie setup
craftsman
iowa
ok i have a 1100 amp pyrimid amp runing to powerbase subs and it seems to drain the batterie a litte its a stardard batterie for my truck? what should i do? should i get a utlum battier or should i do something else. battier good and lights never dim even at idleing
sorry about that but my truck voltage meter seems to read high and today it my amp turn off it was only on for 2 minutes and i was driving it. does that mean im not puting enough power to it. and the amp protection light didnt turn on and it wasnt hot. so do i need a better battier or a higher alternato or could a capaitor solve the problem?
the amp complete shut off.
11
954
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
632
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
9
craftsman
craftsman
iowa
terra
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
