Help!! New altenator!!
Originally posted by beachboy016 My alternator crapped out so I am going to be getting a new one. What is the strength I should get if i dont want my lights to dim when running speakers and subs?
get your battery checked first as it maybe damaged would just blow your new alternator when you put it in. You need to add and cap. This will lighten the load on the alternator an prolong its life
chris....i dont mean to start a big argument but how will adding a cap reduce the load on the alt....wont it become another thing for the alt to charge?
Originally posted by Goddyd4me chris....i dont mean to start a big argument but how will adding a cap reduce the load on the alt....wont it become another thing for the alt to charge?
once the cap is charged it ceases to become a load and would just serve to supply a stiff voltage to the amp and a smoother average load
i appreciate the reply....but it would still eventually need to be recharged every so often since the cap provides extra power for deep bass hits w/ the amp....im not sure how long but it would still be a load tho...this isnt really based on any facts just common sense
Originally posted by Goddyd4me i appreciate the reply....but it would still eventually need to be recharged every so often since the cap provides extra power for deep bass hits w/ the amp....im not sure how long but it would still be a load tho...this isnt really based on any facts just common sense
yup---- but as it just helped with the load before the recharge ------ it is a net benifit
supplies the amp with a stiffened voltage
supplies the alternator with a stiffened load------ by helping on the biggloads an then need recharging------- smoothing the load over time
This can be clearly seen on a graphing scope
would my normal responce to somone asking if they should get a cap or not be make sure your charging system is up to par first be a bad idea or not.....i would personally prefer to have an excess of power from my alt first...but thats jus me
Originally posted by Goddyd4me would my normal responce to somone asking if they should get a cap or not be make sure your charging system is up to par first be a bad idea or not.....i would personally prefer to have an excess of power from my alt first...but thats jus me
no---- your right------ things SHOULD be in order. Good charged battery and proper wire sizes. Good alterntor that supplies a charging voltage. yea ---- it like telling someone to add nitrous to a car that doesn't run right. It will give you more power------ just there is other things to take care of first.
I'm just stating that caps aren't loads and they WOULD help a damaged charging system-----------thing is------ if it's damaged a cap isn't the answer
cool....yea i had noticed you hadnt really been saying to much on any of the post i had stated that on......i remember we used to get into it quite a bit...heh
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
517
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
547
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
580
beachboy016
beachboy016
Los Gatos, CA
denim
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
