Help me with amp!
I have a 200x2 watt amp that i got from a retired audio fanatic dirt cheap. I hooked it up, it has the steady power flow......but no sound..... I replaced the av's and got new monster cables to see if that was the problem...didn't help. I then put it in a different car with a completely different set of equipment and I got the same result. Is it a fuse somewhere or is the board fried? Any input is greatly appreciated. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you have no sound at all than try checking all of the fuses and if they are all fine than take off the back cover of the amp and see if their is any black burn marks and also check if all of batt,ground, and the rem, are all in place inside off the amp. all it takes is one wire to move and that whole amp will fry in an instance.
11
967
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
646
forum_punk
forum_punk
Northfield, Minnesota
kimamandal
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
