SOLD FS: JL Audio W6v2s - Memphis Belle & Alpine Type R
dustinr
Hello all..
Trying to get rid of these big paper weights that have been collecting dust for quite some time now. Everything is in working condition.
First off, the JL's.
(2) 12" JL Audio W6v2's
Spec's are:
# dual 4-ohm voice coils
# polypropylene W-Cone with polyester foam surround
# solid cast-alloy basket
# power range: 150-600 watts RMS
# peak power handling: 1,200 watts
# frequency response: 20-200 Hz
# sensitivity: 85.9 dB
# top-mount depth: 7-5/8"
# sealed box volume: 1.25 cubic feet
# ported box volume: 1.5 cubic feet
Asking $350.00+Shipping for both.
Next up is a Memphis Belle 16-MCH1300
Specs are:
# 5-Channel MClass Series Amplifier
# Class-AB / Class-D Hybrid Amplifier
# Compact Aluminum Chassis with Custon Black Pearl Finish
# Gold Plated RCA Connectors
# Full MOSFET Design
# Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
# Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
# 4-Way Protection Circuitry
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# Optional Wired Remote Gain Control
# RMS Power Ratings:
* 75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms
* 115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms
* 1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!)
# Adjustable Input Sensitivity: 200mV - 4V
# Dimensions: 25.81" L x 7.6" W x 2.4" H
Asking $400.00+Shipping
Last, but not least.. I have a 12" Alpine Type R in a 2.25 cu ft ported box tuned @ 32 Hz. Unfortunately, the box is available ONLY for local pickup due to the weight.
SOLD
Specs:
# 12" Dual 2 Ohms Type R Series Subwoofer
# Power Handling:
* Peak: 1500 watts
* RMS: 500 watts
# Impedance: Dual 2 ohms
# Parabolic kevlar/pulp fiber cone woofer
# High amplitude multi-roll santoprene surround
# Cast aluminum perimeter vented heat transfer frame
# Compound Radius Curve (CRC) Motor structure
# Spiral cut aluminum former with high temperature DVC Winding
# Radial Vented VC Heat sink and Airflow Management System
# Mirrored progressive Nomex Spiders with reinforced layer integrated tinsel leads
# Concealed mount gasket system
# One-sided terminal layout
$75.00+Shipping for the sub.. box is $50 local pickup only.
If you have any questions feel free to text me @ 660-833-8845 or reply here.
Thanks!
Dustin
38
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
324
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
696
dustinr
dustinr
Moberly, Missouri
Team OSC SVT
    May 19, 2024
    May 19, 2024
