Few vids of my MT's
I think your missing the point...... you said it was an unfair advantage because he had some extra batteries and 2 15's in a blazer, yet your rollin' around with a 16v electrical system and a XX6500. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
that was a prior installation.. next is 3 3515s walled off in 12 cubes with 150in^2 of port tuned to 36....3 1750s..... just something to enjoy/impress people whit... call me what you like when you install everything yourself do over 150 at the head rest and it sounds good on screw to techno people respect you... as apposed to people who are fortunate enough to get what they want brag about it and have "pros" install it and get CRUSHED.... i'm thinking about trading my truck in though..... i was getting some cancellation... my head rest score and dash score where nearly identical...
I hear ya, I got a 150 anywhere you put the mic sealed/unsealed on music. //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
I'm louder than you all with one 10", so STFU. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ahh, I love starting ****.
hey now, thats trademarked fool //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
Dont worry those xx6500 dont put out much anyways:graduate:
Ya but I am running an SQL sub, in a single baffled box, with a trunked vehicle playing throught the seats. Not to mention the amp is rated for its max at 1ohm, I am running at 2 ohms but I do have 425 sqft of dynamat extreme (may need more when my 5200 gets here //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif) .
Funny, any review that people put out about these amps are usually on 12V systems and with the increased amperage the voltage will drop so low so you get people who say, ya there crap. Honestly it isn't the best amp I have owned, my Kicker SX 1250's are so much nicer but that isn't a fair comparison, and I do have four of them, still, //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . Now with a good electrical system these amps are power *****s, you can just feel/hear the difference. Matter of fact you really notice a difference bettween 16-18V but at those levels my poor SSX won't last long. Now you can add all the power you want to those Kickers and they will only put out there birth sheeted power. I never really liked kicker but here amps are great, great build quality to. BTW running your ZX's at a lower ohmage will only give you a slight increase and without and active cooling system will run significantly hotter. Polo. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sit in his truck and listen to some phil collins chopped and screwed and you will want out of that truck ASAP.
You couldn't be more wrong about the ZX's.//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
BTW, my pair of zx2500's on 17v put a hurtin' on the xx6500.
I've pulled over 3k out of a ZX on a 16v system, I couldn't get 4k out of the XX.
Anyhow, you still confuse me. You claim you are SQ here, SPL there, and you run 16v and a SPL amp. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If you ever want to hear what a real heavy duty ground pounder sounds like(1 amp/12 volts), look me up.
BTW, my pair of zx2500's on 17v put a hurtin' on the xx6500. I couldn't get 4k out of the XXX
i'll be doing more test on my amp. but u couldnt get 4kwrms out the XXX @ 16 volts, something was def wrong there. im not saying these the best amps out or anything hell im even in the market for diff amps, but not seeing 4kwrms @ 16 volts is insane, what ohm load where u seeing after rise?
I also Ran the kicker amps Amazing amps. i had an older KX with an 2990Rms birthsheet, and u only seen around 3kwrms on 16 v? perhaps im wrong about something somewhere but can u be more specific on the tests u did?
a birthsheet means nothing. The actual power you will see varies GREATLY. Chris i'm sure clamped the amp and thats what the actual output was.
example, my orion 2500d (2500@ 1 ohm) when clamped only put out 1600 or so @ 1 ohm. Kinda disappointing i know.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
Abel
Abel
Chicago,Il.
delvryboy
    Jun 1, 2024
    May 31, 2024
