Engine Whine!!!!
Hey guys, just bought a 2007 Chevy Colorado. Put my head unit in and blew the cheap speakers in it. So I bought new alpines. All was good, until I installed my speaker amp awhile later. Using the same wiring as my old truck, but engine whine from (what I can tell) only the rear speakers. Unplug the front rca's and it stops, unplug from head unit and it stops. Swapped cables around still does it. Scraped paint off ground for amp, cleaned the chassis ground terminal. I Re-grounded the HU directly to the chassis. I also tried a different cable, but it didn't help, if anything made it worse. To describe the noise, its only when the vehicle is running, and reacts to rpm.
I'm lost, any ideas?
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Dylan.S
Dylan.S
Campbell River, BC, Canada
Papermaker85
    May 31, 2024
    May 24, 2024
