Should I run a thicker than factory wire to power my HU?
  • 2
imsickofweed
I got my Escape gutted and Im still dynamatting, but will be starting to run wires and cables and what not. Should I run a thicker than factory +12vdc wire to the head unit? If so what gauge would it need? I would think 15amp is the most it would draw and that requires a 14ga wire, maybe go 12ga for funsies? Will it help anything? What about running a dedicated ground as well? Should I run a dedicated ground to my amp or is grounding to the seat bolt fine? The amp is 900w rms total on 5 channels.
factory stereos dont put out that much power. if the harness was made for that radio there shouldnt be any problems. even if it was an aftermarket youd be hard pressed to find one that draws more than 15A. and if you are using rca's instead of high level that power draw will be alot less. I wouldnt worry about it, save your oversized wiring for your actual amp.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
The CT's are nice, That Sundown is a a frik'n beast!
7
835
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
708
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
822
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
imsickofweed
imsickofweed
Orange County
imsickofweed
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
