Double Baffle Necessary???
Kastlez_
Bay Area, CA
soo... i made my main cuts for my box off ALL 3/4 mdf and i noticed i forgot to add a double baffle into the original plans.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
box: 3.8 cubes @ 32hz
sub: fi bl 15
amp: saz 1500.1
question is.. is it necessary or am i fine?
if you have the extra wood, it never hurts. or you could always make a nice flush mount piece for it that acts as a double baffle (except for the part thats cut out) lol
Flush mount on the inside just enough wood for the cutout??
im lost... can somebody explain
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif 1" vs 3/4" mdf is a factor as well.
Every cut is 3/4" mdf //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
give us a picture of it. i'd say with that sub if the face is over 22'' then add another baffle.
Nothing is assembled yet..
I only have the pieces cut out but the front face is
28.5 x 15 inches
How much is adding a baffle going to throw off my internal cubic volume..
and effect port tuning?
for daily driver setups, a double baffle for a heavy woofer is a good idea, but a single baffle with bracing behind it will be stronger than a double baffle with no bracing for sure.
Nothing is assembled yet..I only have the pieces cut out but the front face is
28.5 x 15 inches
It won't affect your vol or tuning because you can just add it to the outside of the box.
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
Kastlez_
Kastlez_
Bay Area, CA
bjfish11
    May 31, 2024
    May 24, 2024
