Car audio setup (need your opinion)
  • 2
Drifter mike
CarAudio.com Recruit
32
Greece
Hello,
Last year i installed in my mom's car (Mercedes A140 W168) an aftermarket head unit (Pioneer DEH-S320BT 50*4watt) and also changed the stock speakers with new: JBL Stage 2 604C front (6.5'', 45 watt RMS, 91db sensitivity, 4 ohm) and MTX TX-250C rear (5.25'', 55 watt RMS, 91.5 db sensitivity, 4 ohm).
Now i want to improve the sound a little bit so i have on mind buying a TRF M600.4AB amplifier (4 channels, 600 watt RMS max, max RMS power 4ohm 80W*4, max RMS power 2ohm 150W*4, max RMS power bridged 4ohm 300W*2), a TRF VLSW123D2 Subwoofer (12'', 350 watt RMS, dual 2ohm voice coil) and 2 Hertz Uno X 690 speakers (3 way, 6*9", 85 watt RMS, 94 db SPL sensitivity, 4 ohm).
The subwoofer will be placed in a ported, 35-40L, custom box and the two hertz speakers on car's shelf (custom shelf). Both hertz speakers will be connected to the amplifier (channel 1 and 2) and the subwoofer will be connected to bridged channels 3 and 4 after connecting the ''two voice coils'' of the subwoofer in series so the final resistance will be 4 ohms (so the power that the subwoofer will get from the amp will be 300 watt RMS). JBL and MTX speakers will not be amplified.
Could you please tell me your opinion about this setup? Do you think it worths ?
I hope this help, but in my car, i had this issue because it was picking up a signal from the head light (bulb), so I moved the cross overs to...
4
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
551
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
406
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
931
Drifter mike
Drifter mike
Greece
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
