SOLD car Audio F/S
  • 5
Disco Nate
Car Audio For Sale
Thunder1501D $200.00
Specifications
RMS Power 12.5 VDC Input
Low Level Input
Crossover(s)
Low Pass @ 40Hz-200Hz - Variable
Compression Circuitry
Thunder EQ
EBC2 Port
RCA Output
Low Pass Only
2 Ohm Load 1000 w x 1
4 Ohm Load 500 w x 1
Dynamic Power 14.4 VDC
2 Ohm Load 1500 w x 1
4 Ohm Load 750 w x 1
Dimensions (with ISO Feet)
17.8" x 9.75" x 2.1"
45.3cm x 24.8cm x 5.3cm
RE Audio® SE15 15" Dual 2-Ohm (4 total) $500.00
 Dual Composite 2-piece Cone
 Rubbertek Foam Surround
 Cast Aluminum Basket
 3" 4-layer Aluminum Voice Coil
 FEA Optimized Motor Structure
 Triple Stack Maganets
 Progressive Spiders
 Wrap around Rubber Gasket
 600W RMS
 Dual 2 Ohms
 Mounting Depth: 7.75”
__________________
Sub Chaser Vol.1 Cd Now Available For Sale At These
Available Locations Or contact me direct @ (813) 363-8527/omgcarstereo@gmail.com
1. Divine Sounds 8338 N.Dale Mabry Hwy. Tampa,(813) 886-3100
2. http://www.myspace.com/nateharrisfilms
3. 2Extreme Audio Plant City, (813) 707-1448
OMG Custom Car Stereo
Pm sent //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I call dibs on the mtx
A Link would be very helpful. Id be interested in taking a look at some gear
235
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
637
16
Disco Nate
Disco Nate
Tampa, Fl.
Disco Nate
