can i use 2 car batteries?
  • Thread starter <chickenman>
  • Start date
  • Replies 2
  • Views 2K
  • 1
<chickenman>
Guest
instead of wiring everything in the trunk to the battery under the hood can i just put a battery in the trunk so that i wont have to use so much wire?
i wish that way was as easy as it may seem. but it's not. if you have 2 batteries in your car, that extra battery has to be charged by the alternator. and if you have a stock alternator, then you might have to upgrade you alternator to a more higher output so it will handle the 2 batteries. the process is expensive becuase i did it myself. you have any questions, feel free to email. jsons2fly@yahoo.com
Originally posted by :i wish that way was as easy as it may seem. but it's not. if you have 2 batteries in your car, that extra battery has to be charged by the alternator. and if you have a stock alternator, then you might have to upgrade you alternator to a more higher output so it will handle the 2 batteries. the process is expensive becuase i did it myself. you have any questions, feel free to email. jsons2fly@yahoo.com
Not to mention the fact if the batteries aren't identical you need either a solenod or an isolator. And an extra battery will put more strain on an alternator. Whch is the last thing you need when your trying to squeeze all the current out of it you can.
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
217
A Link would be very helpful. Id be interested in taking a look at some gear
224
660
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
Guest
ramos
Decebal
    Jun 10, 2024
