Burning Wires!
  • 6
SoloXCommander
I am running a dual 4 ohm solobaric X 12" wired to 2 ohms powered by a kickerzx1500.1 and a factory head unit. The amp kit the installer used was 4ga. My fuse is 150Amp. The power wire coming directly off of the battery and attatched at side A of the fuse holder continually melts. It heats up the fuse box, melting the plastic inside the fuse holder as well as the outside of the wire closest to the fuse box. This keeps causing it to arch as well as just a general lack of power. So what I have had to do is keep cutting the part of the wire that has melted off and it keeps getting shorter and shorter.
I ordered a 0ga amp kit and it will be here monday, that comes with a 250 amp fuse. Im thinking this is my problem, too much power for that little wire. I guess the only way to know for sure is to see what happens with the 0Ga. I bet i get louder bass and no melted wires/fuses. How awesome that would be!
Your dad must of used tape for condoms and that is how you got here? He shoulda used more tape..
25
Honestly thinking of just putting my bose speakers from my other car and the shallow 10" woofer in the car in driving now. The bose system in my...
39
5K
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
SoloXCommander
SoloXCommander
Austin, Tx
themgators511
