audio control lc8i vs audison bit 10
  • 4
kkjjjmccann
21
maryland
need a line output converter to use factory stereo with aftermarket gear.
is there a big difference in quality between the audio control lc8i and audition bit 10?
audio control is more within my budget, but if the audition is that much better i could purchase it.
are there any other options in the 200.00 range?
so do you need a processor? These are doing two different things. The AC is good line out if you have a factory head unit but has no processing ability. The Bit 10 is a full blown processor that I think you still can tap into a factory head unit. Price difference is what they do and if you need that ability
I consider processing a need when snagging a factory head unit signal. You want to counteract/complement stock EQ and gain time alignment and crossover flexibility.
The DRC option on the Bit 10 adds convenience and preset selection
Rich V.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
This is in a 2015 F150 regular stereo and I'm using the front speakers for a signal. The EQX is hooked up speaker level. I put a cheezy line...
4
kkjjjmccann
kkjjjmccann
maryland
pickup1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
