lolI swear I should hire you for something!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if u want any kind of bandpass for 1 10inch sub and still try to have it fit within 1.2-1.5 cubes....u better off goin ported....bandpass wont fit...ur ported chamber for any 4th or 6th order bandpass will be atleast 2 cubes after sub and port displacementOk...so who is an expert on Audioque subs and the enclosures they belong in? For the sub I'm getting - it needs between 1.2-1.5 cu ft so I'd probably like it to have about 1.4 cu ft volume after displacement. Look at the specs in the link in my first post to see how the box needs to be designed.
try to find someone here locally if you cant id be willing to do it for you. when i find some time. for 40 + shipping + materials.Anyone wanna build me a box with the specs 80 supplied?
im new to the game, and make 25 cents above minimum wage at my current job so every little bit helps ( references and money wise.)good deal there i wont do a box for less than 75 plus shipping
hahaha thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifthen i refuse to make him a box so that you can lolz //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
If at all possible, I would love to take off 2-4 inches of height on the box with the dimensions I gave you (so it would be 12-14" height) and I'm sure the box wouldn't require 31" of width. Correct?Model SDC2.510Woofer Size 10″
Fs 33 Hz
Qts 0.414
Qes 0.465
Qms 3.759
Vas 14.98
Le mH 1.90
Sensitivity 1W/1m 87 dB
Magnet Weight 140 oz
Coil Diameter 2.5″
Useable Throw 2.3″
Continuous Power 600
Music Peak Power 1200
Mounting Depth 6.25″
Circle Cutout 9.35″
