SicAudio 5,000+ posts
did you fart dude?
do you want a 4th order a 6th order or a slot loaded box?
the slot loaded is gonna be the most ideal
Yes thank you, I'm familiar with what a 4th order is..like i said for increased output over sealed and better sq than a standard ported enclosure a 4th order is just that it combines sealed with ported basically so that you get the best of both
but a normal ported box is just fine
lol several of them is where the info stemmed from //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifyou want the link to it dude. i got it right here
how do you determine sealed is 10 and a 4th is only 3 lolz seems like you are misinformed have you ever built 1? do you even have a clue what the correct sealed to ported ratios are?
didnt think so........
This isn't describing a bandpass enclosure. Simply a vented enclosure which happens to yield a 24dB per octave roll-off which is 4th order.A fourth order enclosure (vented box) is a sealed enclosure with the additon of a port tuned to a specific frequency. The port extends the low frequency response of the basic sealed enclosure usually providing a lower cut-off frequency. The enclosure offers a good transient response (second to that of a sealed enclosure), good power handling within it's bandpass region, and excellent efficiency making it a popular choice for many competitors and everday users, but below the tuned frequency power handling is poor and damage to the woofer is likely to occur if over driven. Lowering the port frequency below that of the manufacturer's recommended frequency will only worsen matters and cause the sound to become "muddy"....bleah!
that comes from a well respected source //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well, I think this misunderstanding is stemming from how often the term "4th order" gets kicked around by people who have no idea what they're talking about. The whole "order" thing with bandpass enclosures is a misnomer anyway. The term isn't used to describe the roll-off characteristics like it is with sealed (12dB/octave), vented (24dB/octave), or passive radiator systems (28-29dB/octave). It's applied in more of a degree fashion.which is why i say a 4th order is not a true bandpass enclosure terra says it is i say it isnt dif of opinion or no?
good for sq or no?
i assume with a 24db rolloff it is pretty dang accurate right?
if i am wrong continue educating me as a most definately respect your opinion more than most anyone elses.
Nice of you to say, thanks.ok thank you Cianzo**** you are good //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
