his port length will be around 35 inchs long at 27 hz with 16 cubes per foot on his box. if the port is smaller his port will be longer to tune that low.could u stop please...u will have him tuned to the moon if u keep it up
80
Seems easier I think.if i do one chamber i might as well do 200 inches and shrink from there
the seperate chambers offers stability and lower impedance rise. \if i do one chamber i might as well do 200 inches and shrink from there
what do you want? do what you want! just base it off of ideas and tweek it to make it your own. be inovative and create something of yours.im still not sure though 2 ppl say chambered 2 say common camber
once again you are wrong, will you please just stop postinhis port length will be around 35 inchs long at 27 hz with 16 cubes per foot on his box. if the port is smaller his port will be longer to tune that low.
sorry 27 inches long with 16 ft box with 160 cubesonce again you are wrong, will you please just stop postin
the smaller the port area, the shorter the port has to be. the more port area the longer the ports will be. jus stick on the smaller side 80 sq for 8 cubes is a little on the small side, build a test box n try it out
