2x juggernaut 12s box???
charleson99
hey everyone i have a 2000 monte carlo pace car and recently got 2 juggernaut 12s. i have a rf t30001bd that puts out over 4kw rms,because this is a pace car edition i want to design a box that will slide in and out of the trunk with out hurting too much
anyone have any ideas id like to hit high 140s?
ok im sorry i dont know what parameters is? if you could explain that would be great and about the biggest box i can slide in is around 16x20x36 and i would like it to be as loud as possible on a meter but still sound good on music, 2 different ports maybe?
Does that RF T3000 really put out 4800rms...? At what ohm load? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
o ok here they are straight fom their website
JUGGERNAUT 12
Voice Coil (Ohms) 2 x 1.4
Fs (Hz.) 42
Vas (Liters) 27.6
Qts .45
SPL (1W/1M) 88db
Power (Wrms) 1500
Mounting Depth (inches) 7 1/4
Hole Diameter(inches) 11 3/16
Speaker Displacement (cu ft.) .35
that looks badass dude and i repect that you tune your box low,go low or go home
im goin to go ride around with a friend in his tiburon that does 155 legal with 2 rf t2 15s with a rf t4k to each!
be back in a bit
4800 RMS at 14.4 volts at 1 ohm its a 2004 model before the t40001s were out its badass
Yea, but in reality you'll be seeing over 1 ohm and wont be holding 14+ volts unless youve got a darn stout electrical setup in that monte...
Just saying, im starting your design here in a sec though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
id rather not i like slot ports alot i had one of my premier spls in my monte, the box was 16x20x37 with a 70 square inch port tuned to 42 that did well
547
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
919
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
810
charleson99
charleson99
potsdam ny
charleson99
    May 24, 2024
