20,000+ watt Tahoe From MS coming soon
WOW!
Amazing everytime I look at the thread. Keep 'em coming man!
That blue is SICK!!!!!!!!
Thanks man,i was hoping to end up with a small wow factor when everythings done //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and i cant wait to see my truck that color also
Its not much but its the battery tray/cage stuff
in the picture below you can see the batteries are in there little row "sections" if you will.The 4 batteries are sitting in the middle of each section that is designed to hold 2 each if that makes since?
This is before they go up in where my spare tire went,so hopefully when my hitch goes back on there you wont be able to see the batteries much,if at all
And thanks for the compliment mayne!
How much higher are those going to go up in there, would be bad to bottom out and rip them batts apart:crazy:
you probably wont be able to see them at all when my hitch goes back on there,they are gonna go up another 8 inches or so,probably be like 1 inch of them left hanging under my bumper which you wont be able to see because of my hitch and yeah im not tryin to drag batteries haha
Well if they are going up that far it should be good. Never seen it done this way. I will be interested to see how it turns out:)
That's how franky rio's battery bank is... only it's like 8+/- 16v Powermasters haha
thats coming next year //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif thinking running 12-15 16v batteries at 18 volts in a wall //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif but its just a thought right now
A few sneak peeks of alts installed. .weak pictures tho,keep in mind,this is my DAILY DRIVER ,i know my "under hood area" needs to be "spruced up" which i will have a few things done to it but im not going all WILLY NILLY under the hood so it wont ever be AWESOME under there but i will clean it up a little
better pics to come. .and more progress pics also
Only a testament to their durability evl won't last that long id wait until the mojos gave up then go evl honestly and trust me unlike 99.5 of the...
36
6K
Prob over the Budget after building an enclosure(Struggle to find materials for the budget).. But Id like to Try a 21" sub to see if I liked it...
16
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
98HOEONSIXEZ
98HOEONSIXEZ
Greenville,Ms
maxazor
    May 18, 2024
    May 16, 2024
