[1st build] Ported enclosure help for single SoundQubed HDS3.112
schwol
21
I need some help with my first enclosure build. Pardon the inexperience. I've done a bit of research. I've been trying to figure out this basic design for a month now. I've tried WinISD but I can't for the life of me grasp that at this point. This being my first build, I want it as basic as possible. I'd love to keep my cuts (dimensions of MDF) as simple as possible as well. This will be powered by a SoundQubed S1-1250 @ 1ohm.
Sub specs - https://soundqubed.com/hds3-1/
Vehicle : 2013 Hyundai Sonata
Location in the vehicle: Trunk
Space available (Length x Width x Height): 30" W x 14" H x ~any" D (I have wiggle room on depth. decent size trunk)
Subwoofer make and model: SoundQubed HDS3.112 D2
Subwoofer Size: 12"
Number of Subwoofers: Single
Type of Port (Kerfed, Slot, Aero, etc.): Slot? Something easy.
What type of music do you like?: Everything but LOTS of rap and deathcore
Is your goal SPL or Everyday Music?: Can I have a bit of both?
Tuning Freq (Hz): ?  32hz I guess?
Volume : ~2ft^3 or larger
Questions: So I've tried my hand at WinISD but am having trouble with it. I tried subbox.pro and came up with this design - https://subbox.pro/en/b/anwchHHKJ. Is that website worth my time? This box is supposedly 2ft^3 @ 32hz.
Winisd does not model accurately below 50hz because it can't do cabin gain.
Rap and deathcore are 2 vastly different types of music, there will have to be a compromise somewhere. You will either have to compromise on low end extension or transient response.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
996
16
schwol
schwol
THATpurpleKUSH
