1 amp: bridge 4-channel into 2+1sub VS. 2 amps: 2-channel +1mono
  • 3
aodioxp
Hi,
I am looking for amp solutions to power my JBL ms-62c components and 10w1v3-4 sub. one 4-channel amp is cheap and less stress on my electric system. However, some say that the bridged 2 channel does not sound clear even with the on board crossover and its better off to get two separate amps for different jobs.
any inputs help,
Thanks,
A high output 4 channel amplifier should work fine as long as the subwoofer can be wired for 4 ohm load. A single 4-channel amplifier should not stress car's electrical system. When you bridge channels, they do see a lower impedance. If you connect a 4ohm subwoofer to bridged channels, they will see 2ohm impedance. This in theory could cause the amplifier to run less efficiently, perhaps slightly hotter., but the drop in efficiency from 80ish to 70ish % should not be a cause of concern with a single 4-channel amplifier. If you drive your speakers hard, I personally would recommend to buy a higher output Class D amplifier, such as PPI Phantom P900.4, Polk Class D, Alpine PDX, etc. There should be no heat/efficiency issues with those.
6
116
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
289
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
301
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
360
aodioxp
aodioxp
Columbia,mo
zako
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
