Problem
It's not the port had box for 3 years does it no matter what amp I use.
Most likely bottoming out. Coils are hitting the back plate of the motor. Do this enough and you will get a sound constantly even at low volumes. Might be time for some new subs.
Box tuned to 41 ssf is around 35.
Could be a couple things. The sub's suspension may have softened up and now they're bottoming out at a volumes they used to play fine at. Spiders, dust caps and surrounds can all come unglued. Tinsel lead slap is another possible issue. The enclosure may have developed a leak. You might consider an enclosure that is tuned lower.
If you have easy access to the RCA wires at radio side, disconnect them. If no easy access, use a spare set of RCA wires to plug into the amp...
Love the site, arguments over non-issues, not so much. ;)
13
88
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
848
TSM
TSM
Heath ohio
TSM
