First build log ever
So I have bipolar disorder and I've missed 4 of the last 6 weeks of work from either being manic or depressive. Which has caused me to go through my savings to the point where I'm going to have to put this build on hold. Because of the financial situation I'm in I'm guessing it's going to take me until December or so until I'm able to recover to the point where I'm able to justify working on the build again.
To the site administrators please do not close his thread. As soon as I am able to I will continue and complete the build.
Thank You,
Lewis King
Thank You,
Lewis King
Take care of yourself man. Car Audio will always be there when you are ready. Health first. You're very courageous to be honest about your situation. Be proud of yourself!
Thank You,
Lewis King
Deff hope you get to feeling better. Nothing wrong with taking time. I do it as well. Always take care of yourself as stated.. your health is the most important and well being man. This hobby and others are always here, and there may even be some new gear to look at and makes changes as well. looks Great for sure. Take your time, and I sure hope you get to feeling better man. Best to you.
[Update:
I realized that even though I couldn't complete the installation of the sound system, there are other things that I can work on. I managed to complete the installation of the carpet and roof liner as well.
First I sound deadened the entire roof. Here's a few pics: 20220828_173415.jpg20220828_173518.jpg
Someone needs to practice their photography skills. 😂
I also finished the installation of the carpet
And I painted the panels for the center console parts black.
I'm going to paint the panel below the steering wheel and the glove compartment as well. Once I complete the painting of the actual center console I should be able to put the entire car back together minus the sound system of course for the first time since I started putting sound deadener.
I could technically put in the entire sound system minus the subwoofers but I don't want to do so because I feel that would be tantamount to admitting defeat. And I don't want to become complacent with a partial system. It does feel good to be able to get some things done in the meantime though.
Lewis King
Test fitting. I have some touching up to do but man I did not realize how much work I put in until I actually put everything back together it took a real look at it.
I'm not getting big headed or anything but I'm pretty damn happy with myself right now.
Lewis King
Quick update:
Finally found all of the missing brackets needed to mount the head unit and the Clarion EQ. Ignore the Dual mechless it is definitely not a part of the final build it's just a placeholder for the eventual mechless that I plan on purchasing.
Plus the body kit finally came in. Took me several months to find the pieces because they're not being manufactured anymore. I like the fit though. The plan is to paint the mesh gold and the car black so it matches the interior. I purchased a roll of what looks like metal fencing and the plan is to cut and mount it diagonally to match the diamond shape. It'll look nice in the bottom cutouts that are open.
Still saving for the subwoofers. Probably going to end up getting a Helix dsp since it seems to be a crime against manhood to purchase anything less. So that means at least another 6 months of saving and finishing everything else piecemeal during the wait.
Lewis King
Quick update:
View attachment 43858View attachment 43859
Lewis King
Very Nice man!! Looks Sweet man. I will Vouch for the grill protection needed. Almost a year ago.. i was flying down the Highway @(##@@$) MPH, and all Sudden I felt a huge slam in my 08 HHR LT(2.4). Then temp went up pretty quick. pulled over and My radiator was shot/trashed from a bird that came right through that opening up front with no grill protection. Expensive Fix. after all said and done with towing ect. Spend the $100 bucks on the radiator Grill protection for any vehicle. Doesnt take much to Damage these cheaper made radiators/Thin half Plastic have MM thin so called Alumin.?? Even a small Rock will do it in.. I had nearly $600 Bucks with towing and repairs. Even Damaged my Electric fans.
Update:
Finished the fiberglass kick panels. This was my first time trying to fiberglass or fabricate anything ever in life.
This was the mock up.
I glued cheap $3 Walmart polyester around the pod and the kick panel. I used gorilla glue epoxy.
After that I painted it with way too much fiberglass because after all I had no idea what I was doing.
This is day two of me trying to sand down the way too much fiberglass that I put on it.
What I ended up having to do was to buy some primer / filler and basically put 10 coats on each piece. After that I sanded It down smooth. It took 2 days to get it done correctly with the filler, then two more to send down correctly until it was smooth. I used 60 grit, 80 grit, 220 grit, 400 grit, 600 grit then finally 1000 grit. When I was done the primer was shining like actual paint.
10 coats of paint and 10 coats of clear enamel later and we're looking ok.
Prep hole for cutting out speaker location.
Final form.
What do you think?
Lewis King
Update:
Found DC Audio level 1 12s for $89 each. I have 4.
Found a Taramps Bass 1200 for $119.
My brother's sending me a Dayton DSP!
I'm getting so close to the finished product... Looking for a box builder and amps to power the mids and highs.
Lewis King
After the noise treatments in the doors, floor, and rear of the Camaro, I turned my attention to the firewall. These vehicles have a tube that...
40
6K
This build is more of a working novelty than a practical project. It turned out better than expected really. I'm going to make something similar...
18
907
Original wis
Original wis
Original wis
    May 16, 2024
    May 16, 2024
